K
kermit2
Guest
Finally got the key to work on Challenge Mts 601. It seems to have a smoking problem.
I pulled the valve cover off and it was clean underneath.
I pulled the plugs and did a compression check.
#4 cylinder is at 90 lbs where all others are in the 140-160 lb range
#4 spark plug has what looks like tar on it, dripping down from the electrode onto the center electrode.
Would the oil make the compression low?
I only did a dry check.
I figure a valve seal, maybe a valve guide.
I think my next step is to fire it up and run it for awhile and do another check, as it hasn't been fired in at least a year. maybe if an oily residue is on the valve it will burn off.
I have a pic of the plug, seems like the oil dripped on it after it was run.
I'll take any advice I can get as I am used to working on racecars with new motors, this is new territory for me.
The end result is why I'm here.
