I have operated several different Imps and have noticed that some just plain turn easier and better than others.
This Imp belongs to my good friend Dale. It is one of the best turning Imps that I have ever operated. My 1402 had the rear end totally rebuilt last year and still doesn't turn as quick or consistantly as Dale's. I'm not saying that it's bad, just more average in handling compared to others.
I know that brake linings, master and slave cylinder set up can make a big difference too. I overhauled Dale's slave cylinders and set up his rigging for steering bands. His brake bands were in good shape ( 80% or better ) so we left them alone and refilled it with 50wt strait mineral oil. It worked very well with the new wide tracks.
I operated my 1402 with these tracks for two winters. At times in soft snow, I believe they turned better than the narrow tracks due to better floatation. In wet heavy snow you could tell that the tracks had more grip and a little heavier steering, but it wasn't surprisingly more. I don't think there is any significant added stress to the C4 differential. It is more important that the suspension is set up correctly. No flattened out leaf springs! Make sure the drive sprockets are slightly off the ground for a smoother ride and a more efficeint turning capability.
Asymetrical tracks on an Imp need to be run with more tension than symetrical tracks. The small front idler wheel and the way the tracks are free spanding across several of the wheels make it a little more challenging to fit with asymetical tracks. These tracks are only 3" asymetrical. The original modification would add 6" to the outside edges only, making them 6" asymetrical. I operated them one winter with the 6" asymetrical and noticed a little more drooping or tilting to the side, but nothing out of limit or undesirealble.
All in all, if you want an inexpensive way to add more floatation to an IMP without spending a lot of cash, this is a good alternative.
Here's some better quality pics of the Imp.
