Sylvia Tunaskas
I have a 1986 LMC 1200 with a Ford 300 inline 6 (4.9L) industrial engine. I was told the carb is most likely the problem. The vehicle will not hold an idle (700 RPM) with out stalling. At 12-1500 RPM it will run, but below that it is not good. It works well if you are moving between 15-3000 RPM, but when you slow to 1200 or less it is a chore to keep running. The mechanic checked all the electrical, removed the carb and did a field cleaning and replaced some of the parts and gaskets. He also replaced the intake manifold gasket which greatly increased the vacuum. The carb will function down to 900 RPM with the manual choke at 3/4 closed (but rough). His diagnosis is most likely a new carb. I live near Seattle and the cat is near Stevens Pass. The mechanic does not have a source for the carb and when I go to the auto parts stores they look at me like I am crazy. I cannot find a reputable rebuild shop, let alone one that knows this carb.
The numbers on the back of the carb are: D9JL 9510 J
9170 2513
Can anyone point me in a direction that I can just get a new / remanufactured one in a box locally? I have also been told the composit floats have a tendecy to absorb water, and there are brass ones available. Any help or direction would be appreciated. Thanks
9170 2513
