So it's time to start fixing the bugs from last year on my skidozer 252. It has a ford 300 with points. I'm sitting here at work thinking which may not always be a good thing.
My issue.
When running the cat last year the engine compartment would get really hot then the cat would die, after about 10 minutes she would fire back up and be good to go for awhile before repeating the process.
I had came to the conclusion that it was vapor locking, so my plan was to run metal fuel line outside the frame rail away from the engine compartment heat back though the frame rail to the carb. Bam cool fuel should solve my issue. The carb intake is drawing cool air from outside and the carb stays nice and cool.
Does this sound like it should do the trick?
So like I said I'm sitting here thinking, and wondering if it's not a vapor locking issue could it be the distributor, coil, or points overheating- all three were new last year- creating similar symptoms?
My other thoughts for cooling the engine compartment even more was to reverse the engine fan and blow the air out the front of the cat through the radiator drawing cool air up around the engine to keep my engine compartment cooler. I would of course have to move the rear diff cooler and trans cooler.
My other issue is the rear diff gets hot enough you cant put your hands on it after about 30 minutes. Has anyone put a belt driven pump on the engine to circulate the diff or does the driveline pump work just fine at keeping things cool.
My issue.
