What year is this Bombi
Hi Boggie I have a 1975 and an 1980 this one has the new body stile big front window tapered doors
Does not look like mine
a picture would help , a big front window and taper doors could be a BR100
or even a SW48 need Picture......................
If it looks like this picture it's a BR100 or a BR100 plus the difference between the two is engine size and automatic and track size
These are different looking than a Bombi
But in any case what ever you may have that serial number says 1976
Are they geared the same the newer BR100 only do about 13 MPH . And does this body style sell for more. Do you have an Email address I'll send you a picture . The motor looks the same and the guy says it's a 4 speed steel 18" tracks . And it has old stile axles with the nut on the end. So why would they make two body stiles and basically the same machine . And do you guys sell a shop manual for a 1980 Bombi
Send me a PM
BR100 are the same speed as the Bombi the true BR100 plus can have a additional planet set that slows them down. It was added because it makes the units with 32" tracks turn better
Never seen a shop manual for the Bombis only parts and user
Hi Boggie Buy adjusting one track farther back than other would that make it pull one way or the other? on a Bombi it seems to pull to the left . And Is there a automatic trany and flex plate that will bolt on to that 1.6 motor ? When I order brake bands do they come with rivets ?
One track further back should not do it, I would check if one steer band is dragging or one track tighter than the other, or wheel bearings dragging, tire pressures can influence it also, and sometimes a bad suspension flexitor or
Even track belts with extreme curve to them.
I'm sure there is a auto that will bolt to the 1.6 just do not know which one.
We prefer to reline you steering bands here so they we can inspect them for cracks and stretch. But we have sent just the lining and the rivets but to do it properly you need the right rivet tool unless you know someone with a old drum machine that's what we use.
