what kind of cat is this?
I found this cat for sale but I don't what kind it is, it has a citron engine in it . any help would help. thanks Clair imagejpeg952.jpg
I wonder how much one of these would set you back for the base model. It looks like you can get all most anything you want for it.
Last time I talked with Mark base model was mid forties.
They do OK. A little under powered but geared low enough
to use it wisely. Cone clutch/brake on each side for steering
so. It wlll lock up one side and pivot like a dozer.if you pull
the lever all the way. Or just pull it part way and the clutch
will disengage that side.
