Hello all. Long time lurker signing in.
I've had this about 10 yrs.
Sorry about the lousy nameplate photo, best I can focus. WCFE a public tv station in NY?
I have no idea how much it weighs but it does ok on the flat terrain I deal with. But it is slow and loud. The original idea was hinge pins between adjacent track guides. They were rusted away or broke, so were cut out, then added the inner 3 belts
So now I own st182 that was listed here in the classifieds. Seems solid so far but the primary owner wanted brakes. That lead to many hours of reading and rereading the information you members have provided. So thank everybody except Puckle, who set the bar too high.
Used tan "Big Stretch" to fill in missing rubber.
Was able to find brake parts easily online. For future adjustment it seems like running the shoes up snug then backing off 4 "clicks" will work. ?
Had the idea to reverse all 4 front sprockets...the track drive to get a wear baseline on the plastic sprockets and new wear surfaces for new drive chain.
Could not break the nut loose on the chain sprocket side without more torque than I cared to apply. Luckily someone had lubed the pins (ST3002) well and after drilling and tapping for a 5/16 bolt pulled out easily.
Had to whittle some aluminum out of the way for the axle to clear. The unpainted aluminum shows the extent.
Was happy to see that the bearing housings (ST17A) are made of steel. So I have 2 aluminum spares.
Should the track guides be equally shiny? Seems like all the work is being done on the inner parts in both sides. Alignment mostly rear wheel?
Minor cracking on rear wheel, townies won't fix it-liability, so I stick welded with aluminum rod, didn't like the rough finish on the mating surface. Read something here about freeze /thaw causing problems so I bedded the mounting flange with a thin layer of JB weld, if it works I'll be happy otherwise I'll be out there with a torch and chisel.
Almost ready for snow.
