My truck is hopelessly stuck in a drift, so while I wait for some of my electricians to get out of their 7;00 planning meeting, I'll give you some more info on the Hand Crank. Being a seasoned 35 year veteran VW Hippie I accumulate no less than 30 of the Nuts and over a dozen of the Long crank handels. Even made some home made versions. It is important to greese the end so that it will "spit-out" or disenguage properly. DO NOT LEAN INTO IT! IF it doesn't dis-engauge properly it will either brake your wrist, or your lower fore arm. Not good as these things go. ALSO Make sure your machine is out of gear when attempting to start it for obvious reasons. >
Earl, Ron and I got very proficient at crank starting our machines, at one Vintrage VW Meet, where the pictures were taken that an in the Hot VW's and VW Trends articles, we initiated a "Hand Crank Competition". It was a real show stopper. It completely "stole the show" as the single biggest event at the Meet. It went like this: Get in the vehicle, turn on the ignition, make sure it's out of gear, grab the crank which we had fastened to the side wall under one of the bench seats(3Broom clamps), walk around to the front of the vehicle, set the chocke and throttle right at the carb, insert crank, get it going, close hood and re-stow the crank. This was all done to a stop watch and generally the 3 of us could do it in about a minute and 10 seconds. We had 5 Snow Trac's and one Trac Master at the meet and would instruct people in the croud on how to do it then let them try. This one football player sized guy, who had never 'Hand Cranked' an engine in his life got one of the snow trac's started in just under 50 seconds. The crowd went wild. It was a lot of fun.
