I am very interested in using vent-less gas heaters for heating my basement. I'm just now starting a basement finish project and am trying to decide on what to get, how to accomplish heating. One thing my wife wants is a fireplace. I've looked at the vent-less gas logs and that would keep her happy, and since it would not be on that often, would be a good application for a vent-less gas heater. Right?
I see the wall mounted vent-less gas heaters in hardware stores and they are thermostat controlled and could handle the chore of heating the basement (I think), but I've seen warnings about having these heaters in a bedroom and if they are not good in a bedroom are they okay just outside of one, I sure would not think so.
Then Murph posts this tidbit in another thread about heaters, it had to do with thermostats being able to be set in the mid 30's just to keep the temp above freezing:
Murph, or anyone:
What is the affect of this condensate on the living area?
Why do some states outlaw these heaters while some allow them?
What are the pros and cons to using a vent-less gas space heater?
Yeah there is stats that go down that low. However I would not use them with the higher efficiency heaters. Remember we now take more heat out of the gas and it has a tendency to condensate with the lower return temperatures from the space. This condensate is an acid and will eat your thin heat exchanger. Also the stats that go that low are not typically set back thermostats.
Older heaters less than 65% go for it.
Murph, or anyone:
Holy Carp! I'd be nothing but a baked lobster at that temperature during the winter! Our house is at 60° to 64° for the winter.
