It's 10 or 12 years old. I've procrastinated replacing it. Now I have a good reason to. No picture at all. It's a sony 57" rear projection. It's been a good TV. This is the 1st ever problem with it. When I power it on I get sound for a little bit but no picture. Same for all tV inputs. I do see 10 quick blinks, then a pause and 10 more blinks. I looked up what the blinks mean and found this:
10 blinks = Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board. (these circuit references and their part numbers may vary between models but I strongly advise to get the D board checked and/or replaced if unrepairable at component level) - either way it could be expensive. Get a quote from an authorised service centre before going ahead.
While I might end up fixing this one, I'm ready to get a flat screen.
Any recommendations for a 55 to 60" flat screen for under 1500?
