Are both chains installed? You should have a right chain and a left chain. Each runs power to the front drive axle/sprocket. Are both chains installed?
if it will only run straight and turn right I would look at the piviot mounthttp://www.forumsforums.com/3_9/showthread.php?t=61220 here's a link to my thread where you need to inspect closely
the snow master stuff I know of is up in deering is your snow master a 4 band model with 2 bands removed or a 5 band model with 2 bands removed. also is yours the big wheel up front or or a set of small bogies in front if it's a big wheel model than I have access to a good hub for one but not an axle and I think all of vic's snow master stuff is for the 4 band tracks you really need to isolate the problem if as axle breakage is pretty rare. if you want to take a weekend and fly over I wouldn't object to taking a look at it with you.HI DDS
It will only turn to the right. It does not have any power to the right track.
It must be a broken right axle.
If you know of one and it is 300 some air miles form you, If you could get me the info and contact info,I could fly up there myself and get it.
I am in Fairbanks area and it sounds like it would be just as easy for me to get there as for you
If possible thanks again for the help
ST4B #2072
