Finally got this project finished and took a test run in the field before the snow is gone.
The damage from the Joseph OR run.
Had a friend and Tucker owner roll the two cylinders out of 1/8” plate and I cut out four sets of these circles out of 1/4” plate on the CNC plasma cutter.
I turned the center hub and outer rings to size on the lathe and checked for fit.
I then drilled the bolt patterns on the Bridgeport. I needed 14, 3/8” holes on a 10” diameter and thought I was going to have to use the rotary table but realized the Bridgeport has 10.5” of Y travel. Luckily that worked out because 14 doesn’t divide into 360 when using the rotary table. I also drilled the 6 axle hub bolt pattern which was 8 on 6.5” diameter. I didn’t get any photos of that setup.
Gave all of the pieces a dip in the acid bath to get rid of the mill scale and tacked them together.
The outer ring bores had a shoulder which allowed them to be located parallel and at the correct width. The inner hub was a press fit which held everything together.
Used the MIG to weld the hub and inside of the outer rings to the cylinder. I then used TIG to weld the outside using my poor-man’s weld positioner made with a drill powered 4” rotary table with a hose clamp for the speed control.
Chucked the completed assembly in the lathe to true up the 2 outer surfaces with the inside hub surface that mounts to the axle.
Then a couple coats of self etching primer and satin black paint.
I assembled the outer sprocket using 3/8” shoulder bolts and the inside sprocket with grade 8 3/8” bolts and nylock nuts all with blue loctite. Flat top sprockets were in stock at Tucker and bought two so I would have a matched set.
Got it mounted and put the track back on for test run.
