Track Addict
The outer pontoon bearings are in good shape. One is missing a seal and the other is worn.
I can get a replacement bearing for the original which was a federal 1208GF crosses to a Timken 208SL.
The seal is a National 50304 which nobody can cross yet. Anyone know where to get these?
Also there is one axel nut that is 7/8 14 and about 1/5 inches. The other same thread but huge and you cannot get a cotter in due to size. I can find replacement castle nuts of this size but not with such a short height. The stock one is only 1/2 or so. Most are 3/4 to and inch which will make me loose the washer to use or not but a cotter in. Where can I find one of these?
Lastly one outer cap on the aluminum bearing housing is tapped and screwed on the others are not. Would this be becasue they are prone to fall off?
