ALLEN PARSONS
Some tucker 323 info for you
lenght 13ft
width 6ft 4
weight 3000lbs
pontoons steel
tracks 18in
6 cylinder chry 3speed
How many of the units were made, I do not know.
Why there is no id plate on this cat? I can only gess that it was a proto type of some sort. Maybe with the six cylinder, it put them over the weight limit that they wanted.
I tried to get the oridinal steering system working. I was told that the rear end was a brandnew poisatrack when we bought the unit. so that was the only thing that I did not take apart. And gess what,It was a positrack all right. They welded the spiders to the pod
I had to make a choice, continue fighting with what I had or try something different.
I went and built a hole new rearend. and put a diskbrake system on each side. With two single pot masters. You can see in photo DSC00548 In photo
gallery.
Now I can steer with my feet or my hands. It works GREAT. The cat will turn on a dime. You can steer it with two fingers if you want.
Now this may sound odd, But there is a very diferent way to steer a two track system. As you drive a two track unit you will feel it will rock forward and backwards as you go over bumps. You want to steer as you crest the bump and it will turn instantly. Because at that point the weight is taken off the ends of the pontoons.
Yes I find that at a higher speed when I want to turn I have to give it some gas but at low speed it just powers its way right on throught the turn. As for heat build up in the brakes I have had on trouble at all.
That is the only change that I made to the cat and I have keeped all the old parts
One day we hope that some oldertimer in the tucker corp. will remember this unit and fill us in on the history of it.
We were thinking of painting it next summer. but i think that all the dents and dings give it a story. but the wife wants it painted. what do you think.
Moe&Al Parsons See photo gallery for more photos, I will post tomorrow
lenght 13ft
width 6ft 4
weight 3000lbs
pontoons steel
tracks 18in
gallery.
