dirtbike87
Got my 1542 transfer case tore apart to reseal and inspect and had a few quesions come up. Someone else has definitely been in there before so I'm not sure what is actually correct.
I have 2 different seals on the input/output shafts. A single lip 450095 and 2 piece cr 3192. They all leaked so I'm not sure which is correct, but I would guess the 3192 is right being a press fit instead of a seal lip?
The input shaft from the trans also did not have a retaining bolt on the yolk. It was seemed to be just held in place by luck. Is this correct? There is no slip joint between the transmission and transfer case otherwise.
What are you using to seal the shafts splines to the yolks. This one had copious amounts of silicone everywhere it could possibly go. Anyone had luck with anaerobic flange sealant?
Finally bearing preload?
Thanks!
Thanks!
