Tracks
mbsieg
awful member
PLATINUM Site Supporter
I am curious about track thickness??? I know a guy who used 3-ply baler belting to rebuild his tracks seems to me it looks really thin how thick are the tracks on your machine???? Anyone know how many ply's their are in them???:toilet: :blahblah:
There are several suppliers for track belting. Belting should be able to withstand moisture, be UV stabilized, and must withstand freezing without becoming too stiff.
Check out Fall Line for their offerings:
http://www.fallline.com/ski/trackbeltmain.html
[FONT=Arial, Helvetica, sans-serif]FallLine has been the leader in track belting since 1981. We offer 4 different series of track belting to provide our customers with the proper belt for their specific application.
[/FONT] [FONT=Arial, Helvetica, sans-serif]Introduced during the 2001-2002 season, our 100 Series track belt has shown excellent performance in demanding applications. Its specially woven 4-ply, 1000lb tensile strength construction provides maximum strength for the toughest applications. The 100 Series belt is our premier series drive belt for heavier, high horsepower front line groomers (also available as inside and outside belts on select machines or by special order if not listed).[/FONT]
[FONT=Arial, Helvetica, sans-serif]FallLine's 90 Series 3-ply, 900lb tensile strength construction increases tensile strength by 50% over our 60 Series Belting. This increase in tensile strength is achieved by laying larger cords in a tighter weave inside the belt, instead of adding an extra ply. The 90 Series belt is our standard drive belt for heavier, higher horsepower machines.[/FONT]
Our 60 Series belting has a 3-ply, 600lb tensile strength construction allowing for excellent flexibility & durability at a great value. The 60 Series belt is our standard inside & outside belt for the majority of machines, as well drive belts on lighter, lower horsepower machines.
[/FONT]
Our 220 Series belting has a 2-ply, 220lb tensile strength construction allowing for maximum flexibility. The 220 Series is our standard belt for lighter low horsepower machines.
[/FONT]
[FONT=Arial, Helvetica, sans-serif]We Know Track Belting.
Replacing track belts can be expensive, time consuming and frustrating. FallLine's high tensile strength track belts are reasonably priced and stocked for quick delivery. Refer to the diagram on the opposite page to assist you in determining proper belt configuration.
[/FONT]
