Track bolt patter
Rat Track
I'm looking for info on the 5 band snow master
Trying to find the bolt patter to drill a new set of rubber bands for a snow master
The three inter ones r the same but the two outer r different
I need the bolt pattern for both inner and outer
You need a Grouser. They came in a right and a left, to accomodate the alternating 'herring-bone' pattern. Same with the small grouser. Often owners cut down the tracks which is how some machines ended up with different holes on the outside than on the inside. New, From the factory, 5 belt Snow Master tracks are symmetrical. So you only need one grouser to set up the pattern. Christer has them.
