Tools for the beginner........... DRILL PRESS: A tall upright machine
useful for suddenly snatching flat metal bar stock out of your hands so
that it smacks you in the chest and flings your beer across the room,
splattering it against that freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and
hard-earned guitar calluses from fingers in about the time it takes you to
say, "Ouch....."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle.. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more dismal
your future becomes..
VISE-GRIPS: Generally used after pliers to further round off bolt heads. If
nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
you have installed your new brake shoes, trapping the jack handle firmly
under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off
of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything
you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has
an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin," which
is not otherwise found under cars at night. Health benefits aside, it's
main purpose is to consume 40-watt light bulbs at about the same rate that
105-mm howitzer shells might be used during, say, the first few hours of
the Battle of the Bulge. More often dark than light, its name is somewhat
misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and
for opening old-style paper-and-tin oil cans and splashing oil on your
shirt; but can also be used, as the name implies, to strip out Phillips
screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts
which were last over tightened 50 years ago by someone at Ford, and neatly
rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts not far from
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts. Especially useful
for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while
yelling "DAMMIT" at the top of your lungs. It is also the next tool that
you will need.
EXPLETIVE: A balm, also referred to as mechanic's lube, usually applied
verbally in hindsight, which somehow eases those pains and indignities
following our every deficiency in foresight.
say, "Ouch....."
blood-blisters.
under the bumper.
misleading.
screw heads.
you will need.
