Thats what I do as well on WIN 7 , but I cant remember how or where to go to change the settings.In Win7 you have a hibernate function that works great. I use hibernate rather than shutting all the way down. Win 7 also has a sleep option. If I will just be away a short while I use sleep, this way it comes back up quicker when I'm ready to get back at it.
Thanks Bill, found it again. The only problem is it is set to not require a password, but when it goes into sleep or hibernate i have to type it in again.Cowboy, you go to control panel,hardware and sounds,power options and select change settings that are currently unavailable. Select no password required. Goofy shit where they hide stuff now. Still trying to get the screensaver and display stuff sorted.Might need a walk to clear the head before I go back to it.
I never turn OFF computer ... unless I'm going away for a week or two.
Cowboy,Thanks Bill, found it again. The only problem is it is set to not require a password, but when it goes into sleep or hibernate i have to type it in again.![]()
Thanks BC, I went there and clicked on that and it said do you REALLY want to remove your password? Some reason that scares me a little bit, surely if I did that it wouldn't somehow lock me out of my own puter would it ?Cowboy,
If you don't want a password on the computer, I think this is the approach.
Control Panel
User Accounts
select the account if you have multiple
Click on "Remove Password".
I think that makes it where no password is required on system start or wake-up.
Control panel, hardware and sounds,power options, system settings. then click on the little blue change settings that are currently unavailable. Select no password required.
I don't knowThanks BC, I went there and clicked on that and it said do you REALLY want to remove your password? Some reason that scares me a little bit, surely if I did that it wouldn't somehow lock me out of my own puter would it ?![]()
I don't know
I don't have the balls to try it myself.![]()
Nope wouldn't have a clue how to either, never got a restore or windows disc with it either when I bought it from tiger direct last year, that kind of surprised me too. I best just leave things alone with my luck.Did you burn restore discs when you got it? I never had a computer lock me out that I could not break into it. Had a tough time with a Compaq that the kid let his buddy set a password on the bios one time. After a call to a couple different compaq dealers I found one who could tell me how to jump around it. He offered me a job as a tech. That was back in 96. Used to be you beat most in DOS pretty easy.No wonder my brain hurts some days.
Create a password reset disk
If you forget your Windows password, you can use a password reset disk to create a new one. We recommend that you create a password reset disk when you create your password, so you don't lose access to your files and information.
To complete these steps, you'll need removable media (a USB flash drive or floppy disk).
Go to the Windows website to watch the video. (0:59)![]()
<LI class=step>Insert your removable media.
<LI class=step>Click to open User Accounts.
- In the left pane, click Create a password reset disk, and then follow the instructions. Make sure you store the password reset disk in a safe place.
