Tire for 4t10 thiokol
crafttree
I broke a wheel and ruined the tire (Rear). Schwabs said they could get the 205 15 tire for me and foam fill it. Turned out to be the wrong size 6 lug 15 inch wheel and the tire was way too wide. I have a new wheel coming from stiener tractor. Not sure what size 205 15 tire to order for to get the right width. Need some help on the width to get the right tire.
When the wheel started to break the inner half must have been sticking out at an angle and did a number on all the aluminum backer plates. All the raised up edges were worn down and folded over the bolts and nuts, which ruined the threads on the bolts. I can't remove any grousers if need be without bending the backer plate edges off the bolts.
Crazy weather, almost May and snowmobiled into the cabin to work on the cat. 2 feet left to melt.
6.70-15 6 ply on this one.
Thanks Pixie, My tires are 205-15. apparently the 205's available today are not the same as the old bias ply tires.
