Thiokol 2100B track modification?
vintagebike
It looks like from the pictures that tracks and grousers ( maybe cut) can be pushed together to turn a very wide ,and permit required, four belt into a much more narrow three belt?
different frames-----iam going to be narrowing my pb 240----I added inside wheels to hold up tracks so they don't droop inward after cutting----if you also look at the wide cat the cleats r cut at an angle on the edges----the narrow cat is not----if you don't have a lot of snow u will walk out of the tracks------I do have some recore sprockets for any one looking------I will be cutting the edge of my cleats btw
When i lengthened my pb tracks i went with the tapered ends for easier steering. I'm somewhat different because they are perfectly centered now.
Jim
