how much?
I'm curious, because the office was recently quoted a 250KW backup system from one vendor and a second one quoted us 850KW for less than twice the first bid. (I'm pretty sure 250 would not meet our needs during high use periods)
I have 2 of them so you may be able to get you the KW's you need.
I stand corrected once I looked it up. They're 200KW, 250KVA (I think these are the correct details below). I don't have the specs on the turbine engine but it looks similar to those used in helicopters or smaller jets.
As I recall, each have about 200 or 300 hours on them.
How about $5K each, as is, where is. We could probably arrange a test-fire if we got a pile of batteries to get them started. Price doesn't include any switching gear, MCC's, external blowers, batteries, exhaust shafts...
Solar Spartan Model T-351N (I believe they're now Caterpillar)
EM Synchronous Generator End
250 KVA
200 KW
120/208 Volts, 694 Amps
139/240 Volts, 600 Amps
240/416 Volts, 347 Amps
277/480 Volts, 300 Amps
3 phase
60 Hz
3600 RPM
3 Pole
Sound attenuated enclosure
Fuel consumption: 40 gal/hr
