Ok guys I posted in a previous thread about setting my backlash and preload on my 1980 Bombi. I had to do this because it had just come back from the diff shop with new drum bushings and freshly turned drums. I did all this in an attempt to eliminate the violent clacking sound coming from the diff when the steering levers are pulled hard. Well I got the diff set up correctly and tested the machine. The problem of the clacking sound coming from the diff remains. When you pull the steering lever the machine makes an awful clackaclackaclacka sound from the diff or axle area. I have been reading everything I can on this and other forums and some say its the bushings inside the inner gears of the 'chunk' of the differential. I have also read some posts that this noise is normal which I refuse to believe. If you rode in my machine you would swear the diff is going to grenade if it is driven like that. You feel the clacking sound in the handle as you pull it and it is definitely metal-on-metal.
So I did a test, I jacked up the machine and ran it on jack stands. The noise went away and the tracks spun normally with power transferring correctly as levers were pulled. I put it back on the ground and the noise persists. Another thing I noticed is if I push in the clutch and coast to a stop I hear a different noise that sounds like its coming from the axles, and this noise also does not sound very good and it feels like its trying to bind as it rolls to a stop. I have played with track tension to no avail. The sprockets are like new, bearings appear to be good, and I am fairly certain it is those bushings inside the core of the differential.
Anybody have any experience with this issue that was fixed?
Thanks again guys....
