Tap size for helicoil insert?
Does anyone know the tap size for a 7/16-20 helicoil insert? I bought a used kit on EBay and the tap in it is not the correct size.
I have the hole drilled out to 29/64, as called out in the directions.
I'm afraid it's not a normal thread size, and there for a special tap is required - at a cost i'm sure I won't like.
that's what I always thought too - it was basically the next thread size up...but the Helicoil website tells you every other detail BUT the thread size...
I know the tap part number is 7FPB, it's an STI tap, and the tap major dia is .5062
the helicoil tap is the same pitch as the original thread the major diamater is bigger to give room for the coil to fit in
I prefer jergens inserts my self
you can replace the inset by drilling out the lock keys and spinning them out threading in a new tap the locks in
we used a lot of them in aluminum .
get_image.aspx
http://www.jergensinc.com/site/product_detail.aspx?group_no=3017
tom
