S-Pat,
The blower is a Kubota L2174a, 62", with a 23" fan. The fan seems to be quite a bit larger than most, which I suspect is a plus.
This unit was set up to run off the mid PTO on a 3430, and Kubota says that turns at 2k, which seems a bit odd. The reduction drive is 2.95 by eyeball and chalk marks.
Output shaft on the Rockford is 1-7/16, 60 pitch chain drive to the right angle gearbox. This is 1-1/4x1-1/4, rated for 32hp continuous at 1800rpm.
Line shaft is 1-1/4 common steel stock on 4 pillow blocks.
Shaft to 1-3/8x6 spline adapter courtesy of Surplus Center.
PTO driveshaft was lengthened about 5 inches.
Drive cog turns on 1-1/8 shaft on pillow blocks.
Blue cover is half of an old domestic water pressure tank.
Chute rotator is generic hydraulic motor from Surplus Center, weld on hub and sheaves (welded together) are from Tractor Supply.
Idler tensioner support and drive side curved bumpers are Soloflex parts, as is the front PTO guard.
Snap clutch is engaged with 1" bore hydraulic cylinder, controlled by an old Prince log splitter valve run in series after the main control spool. Large threaded rod above that cylinder serves as adjustable stop for lever throw.
I will probably change the 4 sprockets around after I run it in the snow, if for no other reason than to make life easier on the chains.
The auxiliary motor platform is part of a retired Lincoln SAM400 welder.
Fuel supply for the auxiliary is teed into the supply line for the Bombardier motor on a quarter turn ball valve, fed by a Facet electric pump.
The support plate for the blower drive gear is the motor/pump mount from and old air compressor.
I think that covers it?
Let it snow...
