Gabbott, almost any of that list will work fine. The important thing is it is rated for WET CLUTCH/BRAKE applications. I steer folks towards the JD hyGard. either normal for Usual or the low viscosity for expected real low temperatures. It is usually available, it isn't that much more than generic, and for me, it's just worked. But like our departed friend said "Almost as important is to make sure you check it for water from condensation at least once if not several times per season they have the nasty habit of accumulating it." Either run it enough it get hot and causes the moisture to leave, Install a dessicating air vent, or be prepared to drain and refill.
