First to be clear I am little experience with any masonary. I have a situation I want to change and came up with this idea. I really just want to know if I am on the right track or if I should find another way to solve the issue. Thanks in advance.
I have 5 green septic tank covers in the back of my house that I want to cover in a way that they look better and I can put something on.
The idea is to cut out a piece of 3/4 plywood big enough to cover the green plastic cover. Then apply a stucco covering after I put down the proper paper and wire. I don't know how thick the stucco would need to be and if it would be structurally sound. It only needs to be moved every three years or so, when I remember on time, and most of the time it will be just sitting on the green cover. There will not be a lot of weight placed on it.
Is this even reasonable? Is there a place I can find reference material to understand minimum thickness?
