stripped my nuts
utahwilson
Used a phnuematic impact driver to remove/replace the lugnuts on rear wheels. Looks like I stripped some of the nuts. Anyone know what size lug nuts I need to replace the stripped ones? thanks
if you have the composite wheels with inserts they should be 7/16 tapered nuts, for a stud pilot system. if you have the steel wheels you will have a weird flanged nut. I believe the use of tapered nuts is what cracked my one steel wheel
Re: Snow Trac'n Nome web page
for the parts tsore guy just look up full sized chevy automobile from the 70's fords will have a 13/16 head the snow trac has a 3/4 head
