Hi where can i find steering brake slave cylinders kits for a 69 thiokol spy my cylinders are good. thanks
What type of ATF fluid do you use Boggie?
Boggie, Will the ATF adversly affect the rubber seals/cups in the master cyls? I understood that Mineral oil in the manual brake system is considered a big no-no, but your the expert. I've been using DOT-5 silicone brake fluid to be on the safe side, but its expensive.
bctimber, we have both hydraulic and brake fluid OEM kits in stock if you have trouble getting what you want locally. Bore size is 2.2500 inch.
-Pat
Hi all i finely got back on to this project, thanks for all the info. i think i mite try the ATF. off to town.
hi i go back to camp neex week will get the # for you.did't work out as pland but i made due. i ended up using just stright hydraulic fluid . been good all season a little stiff at -30 but after some pulls its fineCould you post part numbers? I have a Kaman Bearing locally. Thanks.
Ok sorry about the wait. for the thin ring on the puck its hard to read TS 226 or T8 226 had to buy a bag of 15. now the wide ring the ones i got did not work for me (580-328) the OD and width was good but the ID was to tall a machinist could turn down the depth of the ring land it would be perfect . but what i did was used the TS 226 and put a round o ring beside it to take up the side clearance of the wider ring land 3 months no leaks . let me now how you make out .ShaneCould you post part numbers? I have a Kaman Bearing locally. Thanks.
