MNoutdoors RIP
thought I would post this to help others in the future. we just got in a machine a Bombardier Bombi and 50% or more of the time when you would go to start it it would just click. OK normal thinking would be low battery or bad starter selonoid. as it turns out someone had redone the wiring to the start switch and used to small of wire so when you would go to start there was enough of a voltage drop that if the tooth on the starter drive was right infront of the tooth on the ring gear that it would not have enough power to push in the spring on the drive and let it push its way by the tooth and make contact to spin the starter. they had used a 18 ga. wire so what we did was increase the wire to a #10 and the problem has been solved this is not the first time we have run into this.
