Well, after a lot of time sorting other issues, I am to the trans. I can't seem to get any normal shift pattern. I have searched and reviewed Lyndon and others notes to no avail. I have a new shift plate. When installed per Lyndon notes, high side up and to left, I have 1st and second, when installed up and to the right, I have 1, 2, and reverse. I have not found 3 or 4. What other adjustment could there be. The square ball socket on trans seems extremely loose, as does the sheet metal box mounted to the floor. Seems as though there is a lot of play. I was figuring on taking engine out and trans this summer to go through it all. Maybe earlier than planned. I was told when I purchased this machine that it was stuck and then unstuck before I bought it. If I need to get another trans pith the correct gearing, 4 reverse, one forward, where or who do I call. I Shepard there was someone in Cal that has done this. Any advise would be welcomed?
Doug
Doug
