I'm looking for 8 bushings P/N ST 6012 any help would be greatly appreciated. Also wanting to know if dualport motor with heater boxes will fit in the st4. Thanks, Terry.
i would guess you are looking for the bushings in the front boggie set those were actualy made of a phonalic materialyou would most likely have to have a machine shop make them yes the dual port motors will work but you will have to alter the air intake scoop to accomadate the doghouse oil cooler stick around and see how my suspension modification goes might be a fix for your problem
Thanks Don, I pulled brass bushings out I will talk to Alaska tool on monday. On my way to the cabin right now. I will look forward to seeing what you have done to yours. I just got my first ST4 mostly in peices, let the fun began. Thanks for your help, Terry.
terry if you are in anchorage try berring engineering or alaska bering theu may have the bushings you need the bushings are a 1 inch id as i remember right but can't remember the od you should take mesurements on both the shaft and socket thann install them follow up and ream them to fit your shaft with a bushing reamer
