spryte backup alarm switch on oc4 ??
spoolvalve
Hello all, any idea's how to hook up a backup alarm switch on a oc4 diff.? Thanks Del its here-its here!!! winter
Most Ford trannys have a backup light switch on the transmission. This would be the easiest spot to connect your backup alarm. Which transmission do you have?
Hello all, the 1202 has the oc4 diff however the engine is direct drive to the diff.-yea wish i had a automatic !! always looking to upgrade/trade parts! GROUSERS- RIMS a/b/? rims split/a style... Del
Worse case is you can install a flip switch on the dash if you are in an area where there is lots of people/kids around.
A weatherproof plunger switch on a bracket that is hit with the shifter when the transaxle is in reverse.
Hello all. thanks for your help! thinking that Bulldogs idea of a watertight industrial switch is the answer. Thanks Del
