This is a question for the 2-cycle gurus out there, particularly the Alaskan guys who may run my model sled. I've got a '97 Yamaha VK540II snowmobile with a 535cc engine and mikuni B38 carb, has only 990 miles. I've not run it much at all since buying the Snow Trac a few years ago.
I ran it yesterday for the first time this year. It starts, idles, and runs well and clean after warmup. However, it dies if it's not choked, even after running it for a good 30 minutes or so. Any thoughts on what the problem might be? It seems like it may be a vacuum issue of some sort like it needs the choke plate at least partially in place to "pull" against. I'll tear down the carb and clean it good. I hope it's not the bottom end seals...
