it's kind of a leak. i'm not sure what i'll do.
timberline is getting closer .i'll need to do something.
thanks nikos
did you see the hole? it is right above the tin on the heat tube. diamond shape about the size of a medium small pearl. when started on choke at running higher rpm's it blows a good amount of exhaust out.
this is a stale air engine. will it get to the cab?
very strong good running 1200cc .
jim
Some furnace cement and a small piece of heavy duty metal tape around the whole mess.. Just a farmer fix!
I think Nikos might be confused with looking at the holes in the tin for the heater tubes.
JimVT is talking about the pre heater that heats the carb up, it's all one piece on the intake manifold. I think for the Timberline event I would just JB weld it but it looks like your due to get another one with more life left in it. Not hard to find and you can order an after market one. You could also slip block off gaskets where it hooks to the exhaust and just not have a working pre heater. It will still run fine.
I may be pulling the engine soon.
Jim it will require replacement of the intake sorry to say one could make block off gaskets for it but it would impair performance in cold and damp conditions
maybe turbonator has a oxygen mask I could borrow.
