snow trac vid
I talked with Brad this morning he said only about 2 inches. sounds about as bad as we have it here 10 inches to date and it all blew away last week
the other thing I did because corrosion is such an issue with the little magnesium cases is once cleaned. I acid etch them, than coat them with a grey primer sealer which leaves them a nice semi gloss finish that is easy to clean.
just regular primer sealer like you use on auto bodies it works wonders for saving cases I have pulled down cases where the cases are completely rotted away from the studs or pitted so bad they were hours away from leaking.
