Hello all, I was hoping to find these answers in Lyndons post, but no luck. I am sure its there somewhere. But anyway, a few question that I cant find answers to ..
1) how do I check the variator oil level in each tower, is this oil connected to the tranny volume or are they separated by a seal, hard to tell on part breakout.
1B) are the variator towers filled completely with oil or only to the normal tranny level?
2) How do you add oil to the varator, ( is the only way the zirk fitting) or am I missing something? It looks like there was a hand pump for adding it through the zirk or is this grease only.
3) I do have a slight seap in the sprocket seals and I was hoping to change them next spring... Guess from Lyndon notes that your best in pulling the variator, anyone do this with the varator in place? Suggestions? The trap door just does not expose the area enough. I appreciate your wisdom!!!
Thanks for all your help in advance!
Hendog
Hendog
