snow trac manuals
JimVT
a few new snow trac owners may not know about "it's a surprise"
I wanted to post this for them.
I hope this helps.
It's a Suprise was the introduction to Part 2. But before we go there, here's the linc's to various of the supporting stories and technical know-how for primarily ST4's with a limited amount of general snow cat 'know-how'. I have Mike of Snowcat Operations to thank for bringing me up to speed on how to post linc's.
Great Snow Cat Stories, encompases Larro Olson's machine and Also covers the COLD BAY Snow Cat.
http://www.forumsforums.com/3_9/showthread.php?t=7954
DB Cooper and the FBI RIG.
http://www.forumsforums.com/3_9/showthread.php?t=8113
Loud VW Engines, goes into detail about sound from the Heat System
http://www.forumsforums.com/3_9/showthread.php?t=13246
Hood Disasters
http://www.forumsforums.com/3_9/showthread.php?t=13166
What Every Snow Trac Owner Should Know
http://www.forumsforums.com/3_9/showthread.php?t=13167
VW Engine
http://www.forumsforums.com/3_9/showthread.php?t=3895
Tracks ON/ Tracks Off, applies to all tracked snow machnes
http://www.forumsforums.com/3_9/showthread.php?t=3818
Snow Trac Manufacturing History
http://www.forumsforums.com/3_9/showthread.php?t=9271
Snow Trac Brake Systems
http://www.forumsforums.com/3_9/showthread.php?t=9181
Variator, This is a 27 part in-depth look at the Variator.
http://www.forumsforums.com/3_9/showthread.php?t=4113
Snow Trac Engine ID
http://www.forumsforums.com/3_9/showthread.php?t=6825
Famous Steering Wheel, get's into some of "War-Issue" parts used on Snow Trac's.
http://www.forumsforums.com/3_9/showthread.php?t=4132
Snow Trac Parts ID Lesson
http://www.forumsforums.com/3_9/showthread.php?t=3825
Snow Trac Fuel System
http://www.forumsforums.com/3_9/showthread.php?t=3814
So for that 999th or 1000th person that said: "You should write a Book", well, we're half way there.
Now for the Suprise. Part 2 is called:AND THE AWARD GOES TO:... and it will be it's own new"THREAD".
__________________
Reading the full " it's a surprise" will help with many problems. you could even see your snow trac in the many pictures.
http://www.forumsforums.com/3_9/showthread.php?t=25189&highlight=Suprise
So, I'm thinking it should be re-titled "So you want to own a snow trac????"
I'm still thinking I made a good choice in TYPE , but perhaps not a good choice in the actual unit. OH well, 20/20 hind sight.
But without the help of the other users on this forum it would be hopeless.
Thank you all.
Tom
This is great. I really like having the snow trac stuff lumped together. It's a long shlog to do a search and wade through all the other posts that come up. I know in my case this site is basically my only source of info on these things and this helps me out a lot.
I'm just now trying to put my track back together after separating the overlapping seam. What a pain in the you know what! Sure glad I'm doing it my driveway vs in the snow up in the Mts somewhere!
Cidertom, if you ever head out west a bit, let me know, always nice to go out with another snow trac. I've been having fun in the Mt Hood, Mt Adams area.
putting the track overlap on is easy. run it over the sprocket then jog the engine. a block of wood wedged will hold the bottom near the boggies.
the trick is to lay a block of wood under the front of the track. I usually use 2 one length wise to support the track at the center and one crossways stuffed under the track to get the track supported at the right ramp angle on the bottom section. I loosen up the varriator belt ,put the trans in low gear, drop the track over the front sprocket ,than have one of the kids bump the starter till the track pulls up tight. at that point I start installing bolts
Once I get the st where I feel confident I do want to get together. It's just taking more time and money...
I printed a bunch of "It's a Surprise" to have as a reference manual. best resource. I just wish I had read it before buying the ST I have.
Cidertom
