snow trac groomer
JimVT
http://mezohir.technikboerse.com/view/haszn-ltg-p/pistenraupe/1969190/sonstige-fischer-ab-snow-trac-st4-pistenraupe-pistenbully.html?search_id=28849460&item_position=4&current_page=1
Interesting. I'm not a Snow Trac guy but the tracks look more aggressive than normal. Besides the aluminum grousers the approach angle seems steeper than normal. The set up would probably work good for ski grooming as long as you can lift the implements when needed.
it says a 70hp turbo. if you look at the inside photo .the hydraulic controls are on the center dash.
I just discovered you can change the page to english
I selected english but it did not switch over for me. $25,727 us dollars though. The passenger side of the cab has been widened by about 10" or so too.
