Snow Trac Electrical Diagrams, etc
Here are the best two Snow Trac ST4 electrical diagrams for simple minds like mine. I'm capable of basic electrical work, but don't have enough experience to know all the symbols used on the diagrams. I would presume the other models were wired in nearly identical fashion.
The first file I've attached shows a simple exploded view of the wiring that is very easy to understand.
The second file attached actually shows the wire colors used, which makes things easy (as long as you use the same colors when you rewire your Snow Trac).
