Snow Trac boogie jack
OldShopTeacher
I needed to replace a couple of boogie wheels before I could remove #599 ST that I just purchased from the trailer. I knew of the lever that was posted but one of the boogies was beside the fender so the lever would not work. Kirk told me Jim had designed a jack using an old VW jack. Before I could see some pictures of the jack I grabbed a spare VW bus jack and engineered it fit. It works great, I can raise a boogie wheel using two fingers! I did have to shorten the length and weld a foot on the bottom and a hook on the arm. The hex head to raise the jack is the same size as the boogie wheel bolt.
OzdFdknQF8hOmuqZQ9X9WcuKCGwD7VXdYponjKnTI18INoOgo1K-dTVNVB4YwMeRXzRsIpATYSgEns81v2Ci7wjJ7WQQa1vJ7COJVz1FlIWtr-Cs0XnUM_ZXDiulaA21U5DW5K80nmhQLwYy7hxExcGmSbO50ai-ddHBfOFnihIV_4MBiCiB-R8AnPFbm1uFrurs5tapYHS4utCQNtUk4HOK7EPYE5aM_J5XMErvdN4fQxl7t256Oty7WsXgI-WOjxVbf1uwTRyIZKgbchTXjnygUVhg-Tb9wFHebeA7IhA-J19s8Q_NFGz3q_cM5mTkIsb5OaFh95wno9seqwVXwZNKDGioATd9h8RUEMwjiBMrf7aizdCqaAmoq4cPvCEf26YvMV3wFO7oG-kCXONQTU3P3lmDTAJfSjDM_YPzbvxzJc5eM_MWwjRlPZg8MWqU01FBKqbHsClAFpt2Vu_b6SXG2GXSEpwayv_xXlmjwpnMu4OcEm0AKctGTEj0mz6gIgBeBJeZEbrBFFfPXxCjKkh7z83YFFRu2UKjZbCFh_rQJrTmbfi24qXa7HP89Kig0uYGv8kDsajYT2izD15kuoqQRtFPPCz1fIOA0PVEMXAToI0Gtn0=w830-h622-no
ngFYVvvtaL4pzxJbEMwu6nKtMEZuLRA-6iBKqFr7BiDyAR57xXOni8wROR5dPRWXnA5ZjQk7JIuez0_g35BMv7Qa3YRwTOIHiiDkmQFuo9seSGRfEQKugD1ogG9lQm6Xcv7D0B4EeJlDLQ40HcOx5HNc2w1euRh16DYWaQkCpTJvd_KSOervbqYRiie2G3vSxrzL81Uw9nQJZIYnDna39WzbzgfM0ksPMjSyme9xwNe9f1vo19iVqwQNdbCbCTltR61p0ct2KO2V1KbhTAjdLAKsysiXQ5j0IVKqHujzLjxB_OqHRJ0wR4osSeCYywQ9Nc4ijsF6iRivEWKONp4_diJ0YSVavm0a88KvozRSkoSJVsS5CFBdsWCAkHbE5vsNE3lXHtS9TYcQd0WvDqda-DGmTiQeSDyCEDyydlukMKeta7g4I7ISqF-f-Y5oF83eS7F63b6OvgYYXVXzR97DbkWfAi6rgpEW9J1mwoMtQYHCnF4yhceTOUYoVS8hUlcqDbyEqaMFvpMP9jPl4xsQUslk4EY895GY26CJYX4YMVvpgqlPJz4LpzfAhg0bc-FAxe1i_W_FnEtHc3N0MAr7c18RFDK-hjo_8c0Z3cHerBZMtc5htNA=w830-h622-no
ZvOa3-xM6erKYJmicXctKcbWA3KRVCdxeLJ3M_Vd8n0WimLVlKXT7S9cyxE2iuJxaOUIiZWxfttpuzndqAit8lkmEH2wPXYbit9VDnJ-z3L6bcH3ifvtsVcWes7ihEh-scsRNrdZqcEActiawV_DW4Bk2ck6cawBjwprm9vD08vi-M91dyE8mlJWZf6Gn5l7kHsMj4E6a2Ivep6CT86v7aTrRHaCMWivODGIronGnDhszLIhl2OAdgyiBTb7CU-rIvRPB_lzsqB_OHS1BNa9HZqkNbWvyZtrwRUVwqPPU_l4hIgqc2fyrMAj1lhyn_nGKOgqaiqBqMppsIrT4q3uMzrgJJg8XSM9SfUPE6jeZ541XmDGb8Vkf8fH_bwrLfaLwnYqGgLWBi9jYmUXlrXl14cRgT7llNPl29Ky22CRdM_xT2g61o4ez43f-tUlYlc7t4f905UoWSAz5cne7W49N54e7JVhUwlhd9nmfMZRCbGq9tRyO7h4zb8XMrsLHKyrrQYLgBPVT61kU4Cr0pO8G-3SSATDOxC386kC-cAGh7ppi26E8R1WPke_QW38lge1wqBwpycB3mpX0ilp0FN1tjV2yJbrHANJ-wge79tc8Z3YoJJpUq8=w830-h622-no
o4TqrWRBtgH-NdcDHzOceJUDZNLR4ge2LcNS5H-YpDo5bSeEzI9JQHYkmjdLDYe9ReITiyqsQ309pDhqMLA9ghUz2XMskSIIHh8-5q4L83vEOsYnOaH2J7ooIiD-PLeGbLlWDLNsvJJz2EnaXXoSOEJov8iyi7kjP47Zc-6XUEnfRdaxynAmRPCb2pikw2-7gFWP4xiMALlkeHirhms2x8M8jscfmN9LS5kCRTTEKitI8poP6gEVE-0wR11INMq9mxCPtvqUHbAORPGfAR33VAh8pzVV2HTafV0ZtYLbZAejyjDBeAtGluRrWXmzRmths2h9mt_sr0ZLI6QEA84fCADkoOo-0EPQe-BA7nSJp2Vjt5sats25xGJHaazFvYhvEsADnk1C2TwGZTwjsz9h8gzYFpYyM5MCYZsC0WyIMqWjUO_ThO4nxwCyFx1hCqtN9p3OIokfZ_ccD23S1oIKOEW3xrnQCCKHgHCVbTXGLfOW8X7dhoZTMAuZIMuwxbzUGv3DHudNbgMnVvj6gyY2GXFQnNt3tDYLk398f7iXxi-CG9mgqt1ljCl-QnBhDJXFCb0LOpiE-RyQZUe1gf-vSVZwyxZIaHp5ya9n9_P7L1aVtYDcN8Q=w830-h622-no
xFPjs1XMXRqKNKDNCb7-gQOoNl8AJWE03zLWyEGTwZbdiMq7dXd_82rn7A7hYDdcKuvE4zjwTB8geERBzoI5d8-Fe05C24sst_xUqRvDh6RXe6HpI6xYXHDcFgxascJt90EoDWiIJz4tMPC2ZOjUQL6KGr_stAvRwkRhh4xw6RJ-eZCi8JqvXv922BR2sz_pywov0CWVzaV1K5Hoc_FowONYCCfW3vZdew9WOQEUQeoX7Xw-b956VCWppKmkBCW9mAG9tgsAYfJEJKvboTc3Gwtq2gAoot5h7KzTd71Cws3XdJR5hqgZZ37JCe0IJjh4pvYKiwD1ucZzkenHVVNkAP2iryaA0QYIHC3ZYzYr_bYw4ykbGNFY5J01WNo4k5ps67hME0goHeY9blQ3J_0xPUI3zm_wJLp0PES0Y-u-FJMroWarZAnaf8gF0Ov7wK0bK90ezhsquuNs6vlk06a-mflNfcIfcBTW5o3KfSh3mYlWbER04Fb1bFMTaLnl51jpKrOQPPP0mYIyH_KlrCnF-e0NI_I3MjT0Fyo9W6_KrG0KCmloGkVZZaSvvDkEoqrxmTzUX-jcqsJiBrjQZH_pB9Y7RxQSc7DuNmkve9WxHhWkiVQi1VI=w830-h622-no
I don't think you can get much better than that.
now find a good place to store it.
really easy work while it is on the trailer. I hope you rim is ok.
Thanks Jim, after all it was your idea that started this. But I didn't know you were using a car jack, all I had was the bus jack which works well.
I am also going to use your idea of solid boogie wheels so if the rim is damaged it shouldn't be a problem. I will be ordering them shortly for both of my ST's, 28 in total!
I don't think mine would have worked in that position.
you must have driven with a bad edge guide.
this saved my day at McCall. hand crank
Jim, what size VW engine are you hand cranking? My engine doesn't have the crank nut on it but I can get one. I wonder if a 1600 could be hand cranked?
1600 starts easily with a crank if it is tuned up good. snow trac's came with hand cranks and the last ones built had 1600 in them.
I have the 1600 in mine.
