snow trac boggie wheel hub replacement
JimVT
I am in need for some kind of a fix or replacement for the 4" boggie wheel hub on my snow trac. Has anyone found a center that can be welded in the rim or an replacement?
Jim
what is wrong with yours are they cracking or just rusted out i have 2 nos here i'm going to send out to Bob Skurka but i also have a bunch of used ones and i have limited access to a few more. tilll i found the stash of nos wheels i was a little leary of giving up to many spares be cause the solid tires i have seem kind of hard on the wheels. pm me if you need some i have a few pulled .
Don, The bearings were all wiped out and not knowing how it came apart I thought it was trash. I got some help today and I think new bearings will fix it. Monday I'll swing by gerrish bearing and pick some up.
when is the last ship heading out? Is freight to seattle expensive?
big stuff can be pricey but that little stuff can go u-s mail in flat rate boxes if you have the old style hubbs with greese fittings you can get timkin replacement bearings the new style bearings used with the 3 band track and big wheel riggs have a special sweedish bearing that is expensive.
