Yours would be a 'first' as the hundreds of machines I looked at, owned, and worked on all had them. They are shown on even the earliest service manuals. They used a 'dip-stick' sender which was only used as an option on early VW Products,.. not standard equipment. Some outfit in California still sells a replacement dipstick temperature sender. It and the Guage were VDO. In the earlier article, with the link, the final permanent "Fix", relied heavily on setting the Fuel/Air Radio with an engine gas analyzer. Most aircooled aircraft have temp senders in the manifolds or on each cylinder and one adjust the Fuel/Air Ratio as well as the Spark to keep from over heating. The engine compartment ran so hot in ST4's that it often burnt up the Fan Belt, or started damaging the Variator belt as well as cooking various gaskets and threatening the Coil and associated wiring. The "Rulle of Thumb" is: If you Can't hold the Dip Stick, it's too Hot! Bug engines like to run Hot, but not too hot. Also the Death of many VW powered machines was the over heating led to a rubber fuel line coming off in the engine compartment, followed by a disasterous fire. There was an FAA ST4, just north of you, in Kotzebue that I looked at and I believe that is what caused it to burn up,... removal of the air induction horn. Once the engine caught on fire, it set one of the Big wheels in front of fire which in turn burned a hole in the fender, big mess! It sat there at the Post Office, dead, for a year or so then a guy who owned a Mine way inland bought it for parts. He had several machines at the mine, he liked them as they could be fit in the cargo door of a early prop job, like a DC3 or DC6. I dread to see what they look like today! It was not Red Dog, some name that started with a 'L' I believe. Probably NOT on Mapquest.
