the subject came up a time or 2 in the past and I found a great chart to guide one on what a safe ice thickness is. http://www.bigice.ca/ice_chart.php
that's good guidance too with a little more fudge factor built in to it. both will give you good safe guidance as I have exceeded those weight limits for 4 to 6 inches of ice in the past.
absolutely and well said I know if I wanted to I could fudge it, if I wanted to and have done so in the past. it doesn't take too many cold baths for one to be concretive about crossing ice even, if the cat can cross, one doesn't want the load behind him to fall through.In reality, most cats can probably travel over ice that's significantly thinner than these charts. These recommendations appear to be for people on foot and wheeled vehicles, and thus would be very conservative. An average person on foot exerts about 2 psi, while an average cat would be +- 1 psi depending on load and model. Therefore, you could theoretically travel over ice half as thick as recommended. Personally, I'd stick close to the chart for safety buffer to avoid a cold bath. Thanks for posting.
