snow cat steering brakes
Not for sure, but would limmitted slip diferential additive work? It definately helps a car differential, to keep it from chattering in turns and make it hook up when needed. This is with a disc clutch in the rear, and I am wondering if the brake band material may be much the same. It could take alot of it depending on capacity of the system your working on. But it may not work at all for all I know...
