All in fun. I brought it directly back to the heated shop. I was surprised, I pulled the plug about 24 hours after I put it inside, it had not separated at all. It is Cat power shift oil, it's like the oil absorbed the water and made ice cream. I would imagine left alone long enough it would. Now to try's and get the system clean again. Probly use some diesel and try and get my hands on some used atf to flush it through the lines and cooler.
The overheating has me miffed. I will check cap, thermostat and timing. Exterior of the radiator is clean. I'm going to convert to EFI, so,that will help possibly. It was about 30 degrees, chosen gear didn't seem to affect, like I said it was once i stopped is when it would heat up, but it would run 220 while driving got to 230 when stopped according to the gage which I'll check with a gun. I believe it because while it didn't fully boil over it was dribbling coolant out the overflow over the coarse of the trip.
