Seeing my doctor again
JackieLynnM
USMC Veteran
Iraq War Veteran
Seeing my doctor again, pinched nerve in my lower back and it started 3 years ago. I was working on a customer's car pulling on a wrench one day and suddenly tingling and a sharp pain in my lower back started. Sat down and called my doctor's office which was the smart thing to do on my part. I was lucky to get in that day and found out I had a pinched nerve in my back. Knew I did not want the surgery yet and they had me see a chiropractor which did help not needing the surgery. Trying to void the surgery hearing the horror stories of nothing going right after the surgery. 18 years of wrenching putting a toll on me and having this and I am not 28 years old anymore. My doctor understands this well, she does know I work on vehicles, semi trucks and heavy equipment.. Hopefully her having me see a chiropractor. Going to ask her about the Teeter back machine as well before I order one
As another bad back person look at pain management it can be a crap shoot but my 3 ablation's one worked 100% the other 2 better than 50% it was still better than actually needing to be cut it made bad days bearable and some times there's great days without any pain.
I’ve had back problems for a majority of my life, but not nerve damage, or at least not that I know of. It’s been pretty bad sometimes to the point of laying on the floor unable to get up for a day or two and only to get to the washroom, had to go to the ER once and they gave me a shot of morphine and sent me home then spent a week in bed before I could move enough to get to a chiropractor. I started going to chiropractors probably around 11 years old, and thinking back some of them made things worse instead of better. About 10 years ago I went to a massage therapist and that was the best thing I ever did. I can still remember after I went, I went for a walk like she told me and drank lots of water, I laid down for a bit before supper and I remember laying there and realized that nothing hurts. For the first time that I could remember since I was a kid there wasn’t something hurting or aching. After a few more visits she mentioned how my hamstrings were always tight, and thinking back I remembered doing different exercises in school that that hurt the back of my legs and lower back. Likely had I made that connection then I might not have had the back problems all my life. I now regularly go for massages, have one tomorrow actually, and take time to stretch and make a conscious effort to avoid doing repetitive motions, like alternating which leg I use first to climb in and out of trucks/equipment . Also sitting with your feet up like in a lounge chair plays hell on your lower back. People who have never experienced back pain has no clue what it’s like.
I'll not argue with that. I've been a back pain sufferer for almost 40 years. I won't let them cut on me either. I don't believe in the "Heal with Steel" mantra of those surgeons who carry out "experimental" surgery every time they operate. When the success rate for some procedures is way less than 50%, they'll wait a long time before they get to practice on me.
Looks like we're all in the same boat here. I'll hop on board the ss badback. 😆
I totally understand the muscle and nerve damage after being run over. I literally had a tire tread pattern bruised on my back for 8 months. I'm on nerve pills along with naproxen and mmj for pain management and go to physio every 2 weeks for "cupping therapy". It really helps loosen the muscles.
  • Like
Reactions: Doc
Good thing is no surgery and ordering one of those teeter back machines. Seeing a chiropractor too next week
My son has one for his back he hooks both feet in the bar before he flips over you might need some velcro ;) ;) ;) ;) ;) to hang there on one leg good luck.
I use the local YMCA pool with water aerobics' in the deep end with an aqua jogger belt to supply traction when floating in the deep end of the pool it relieves the pressure on my back. If I miss a couple sessions im paying for it before the next one.
If the crew is like ours at the Y we have a couple of people that need help being steadied on the steps on the way in and out but we are there to support each other.
  • Like
Reactions: Doc
Frank, me nearing age 65 in March, I've had back problems since I was in my 40s.
It was advised for me to have back surgery around age 42.
I'll never allow that, ever.
Too many risks.
I manage the pain now with ibuprofen and arthritis strength Tylenol.
Also topical creams.
I have a back brace, but it's a pain in the ass to wear.
I'll live.
44 years in nursing has taught me one thing.
I'm tough 😄
听起来你经历了相当大的挑战!下背部的问题确实很麻烦,但我很高兴听到你找到了脊椎按摩师,而且这对你很有帮助。避免手术是一个明智的选择,尤其是当你听说手术的一些负面结果时。如果你正在考虑购买 Teeter 倒立机,我建议先与你的医生讨论,看看它是否适合你的情况。许多人发现倒立机可以有效缓解背部疼痛,帮助放松肌肉,减轻紧张。与此同时,保持适度运动和良好的姿势也很重要。我希望你的康复顺利,早日恢复正常的生活和工作!
That's easy for you to say
Here, let me translate it for you.
"Sounds like you've been through quite a challenge! The problem of the lower back is really troublesome, but I'm glad to hear that you found a chiropractor and it's very helpful for you. Avoiding surgery is a wise choice, especially if you hear about some of the negative results of surgery. If you're considering purchasing a Teeter handstand machine, I recommend discussing it with your doctor first to see if it's the right fit for your situation. Many people find that handstand machines are effective in relieving back pain, helping to relax muscles and reduce tension. At the same time, it is important to maintain moderate exercise and good posture. I wish you all the best in your recovery and a speedy return to your normal life and work!"
The Teeter handstand machine,it was discussed as well and said this would help in my situation too. Most of the heavy stuff, I use an engine hoist to pick up stuff, one is transmissions
