tiredretired
The Old Salt
Dug out my weed wacker today. It started, but when I would give it the gas, it would quit. Sure sign the carb is acting up.
Took it all apart, changed the fuel lines and checked the gas filter. Filter OK.
Took the carb apart on the work bench and checked the needle valve. Needle valve OK, but it appeared the screen was partially plugged. Aha, there is the problem, I say.
No, the problem is me. I never knew it is not a good idea to use carb cleaner on a two stroke carb. Messes them up big time. After putting it all back together, it ran worse then before, if that is possible. Should have just used compressed air or taken to have it cleaned ultrasonically.
Found a new OEM Zama carb on eBay for 22 bucks. Local engine shop wanted 75 bucks. Ordered on ebay.
Sometimes I'm a dummy.
