jwstewar
I have an old cement mixer. I've probably had it 15 years. It is probably from the 30s or 40s. When I bought it, the guy plugged it in and it ran. I brought it home, plugged it in and the smoke immediately escaped out of it. So I've never actually used it. We got rid of our above ground pool with a fairly new pump. It is either 3/4 or 1 HP. I thought, that should be plenty to run that mixer. I proceeded to pull the pump part off the motor and bought a new pulley and mounted it on the shaft. It fit right on but it won't spin the drum. I can spin the drum quite easily by hand. I even tried to help it start by hand. It will start to turn for a couple seconds and then kick a thermal overload and I have to wait for it to reset. What is wrong? I noticed yesterday the motors at TSC have a starting solenoid. Is that what this motor is missing?
I've attached a picture of the cement mixer with the new motor attached and the old motor that was on it.
