What's the easiest way to replace a track on a snowcat. We've done it serveral times each time doing it a different way. I want to know what works for you guys. What's the easiest way to remove and install a track.
The reason I ask is that we just did the two front tracks on the lamtrac yesterday including new sprockets, belts, and cleets. Getting the old ones off was the easy part. One track was shot so we just cut the rubber. The other track, we are keeping as a spare so we took the time to split it where the belts join. Getting the new ones on was another story. We jacked up each track, removed the hex nut that locks each hydraulic drive so we could free wheel each track, then with great care and a few choice words, got the track up over the top idlers and sprocket. We removed the front idler on each track to assist in getting the track into position then re-install the idler. All we needed was 5-6 strong guys, a couple prybars, some chain, a four wheeler to tow the track in place, and a well stocked dictionary of choice words to use.
